you39 Posted December 6, 2019 Report Posted December 6, 2019 hello everyone.Please help.I have a program for the machine written on protool and Strp7, When I want to open it to add changes to it, it gives me the erroropen object 734:26 OM TD/OP: simatic-op is on a write-protected medium.please tell me, How can I overcome this problem?"Unexpected file format" Attached images.Thank you for your help Quote
pcmccartney1 Posted December 6, 2019 Report Posted December 6, 2019 Pretty sure it's telling you that the memory cards in each device have their respective write-protection switches turned on. Just turn them off, then when done, turn them back on. Quote
sigmadelta Posted December 6, 2019 Report Posted December 6, 2019 Another thing that it might be, is the files are read-only. Find the Step 7 project folder which is in C:\Program Files\Siemens\Step7\s7proj\ and right-click on it an click Properties... uncheck the Read-Only checkbox, and if it asks, apply the changes to all files and folders. Quote
