wzrdstrm Posted December 30, 2019 Report Posted December 30, 2019 Not new to PLC's, but new to Mitsu PLC's. Seems like old TiSoft. Couple things, should be easy for the experienced. I created new logic, simulated it, added to online program at the bottom of the routine, just before the End line. Logic appears to be skipped and is not updating. Preceding network is a Return from a call. Why do they not update after that return and at the bottom of the routine? Second....please, When I cut and paste a network in Monitor Write, the network I paste does not highlight that it is an edit, if I click on a contact in the network I pasted and change a contact, then the network shows it as an edit. Comments? TIA
krishna k Posted December 30, 2019 Report Posted December 30, 2019 45 minutes ago, wzrdstrm said: Not new to PLC's, but new to Mitsu PLC's. Seems like old TiSoft. Couple things, should be easy for the experienced. I created new logic, simulated it, added to online program at the bottom of the routine, just before the End line. Logic appears to be skipped and is not updating. Preceding network is a Return from a call. Why do they not update after that return and at the bottom of the routine? Second....please, When I cut and paste a network in Monitor Write, the network I paste does not highlight that it is an edit, if I click on a contact in the network I pasted and change a contact, then the network shows it as an edit. Comments? TIA Hi wzrdstrm, If your new program is not working means either the rung you paste is not executing or their may be double coil error... Please check is your rung is working by putting a timer in it ... Orelse contact me on my WhatsApp +918610724575
wzrdstrm Posted December 30, 2019 Author Report Posted December 30, 2019 I wish it were that easy. I cross referenced the logic I used before using it, no duplicates. Even when proceeding logic it true, a move statement is not working. It has something to do with the area of the routine I put the logic in. See pic were the move statement remains a zero. Step 20762 is true, M8000 and M8001 are true and no coils used anywhere else in the program (it won't turn off it is SET), the Comparison from D400 to D8002 is true and hence the Move from D400 to D8002 should be moving 377 into D8002. This was tested in the simulator first before entering and working. 1
Ron_S Posted December 30, 2019 Report Posted December 30, 2019 Which plc model D8002 is a reserved register in fx models
wzrdstrm Posted December 30, 2019 Author Report Posted December 30, 2019 Q03UDECPU. I remember having this issue with a another type PLC, I put all the changes at the bottom of the routine, as stated just before the END, so as not to get caught in a GOTO type issue. Could it be a range issue?
wzrdstrm Posted December 30, 2019 Author Report Posted December 30, 2019 Device points for Internal relay states 8K, not sure if that is absolute, or restricted to 0-7999?
Gambit Posted December 31, 2019 Report Posted December 31, 2019 (edited) 15 hours ago, wzrdstrm said: Preceding network is a Return from a call. Why do they not update after that return and at the bottom of the routine? This is because you placed the ladder after a FEND instruction. This means the end of a program after this all the subroutines and interrupts are programmed. As you are using a system Q subs can also be placed in a different program but that is another matter, this program is probably converted from old a series as also no labels or structured programming is used. Just paste this program just before the FEND and it should work Edited December 31, 2019 by Gambit
krishna k Posted December 31, 2019 Report Posted December 31, 2019 13 hours ago, wzrdstrm said: Q03UDECPU. I remember having this issue with a another type PLC, I put all the changes at the bottom of the routine, as stated just before the END, so as not to get caught in a GOTO type issue. Could it be a range issue? Hi Can you send me the program I will check and will contact you krishnakum.ice@gmail.com
wzrdstrm Posted December 31, 2019 Author Report Posted December 31, 2019 Wow, they had a whole pile of subs, they are called from C# to a P# (or something close to that), found the FEND, TY, have to try it now. I think I still have to stay lower than M8000 though, as previously noted there are only 8K of internal memory bits configured. It may have originally come from an A CPU, we have one machine of same type using a Q2, these are Q3. It also looks like they can do some ladder FOR loops, have to figure that out eventually.
Gambit Posted January 2, 2020 Report Posted January 2, 2020 8K is 8 x 1024 =(8192) so your good. If you do an online => monitor => device memory and enter for instance M8000 it should to M8191 for the last M device
wzrdstrm Posted January 2, 2020 Author Report Posted January 2, 2020 Roger Gambit, wanted to look and work onthis today, but we had an analog card burn up...oof
wzrdstrm Posted January 6, 2020 Author Report Posted January 6, 2020 Roger Gambit, wanted to look and work on this today, but we had an analog card burn up...oof
wzrdstrm Posted January 6, 2020 Author Report Posted January 6, 2020 OK, memory checked as stated, thanks... So I moved everything only to realize they had a jump going to the FEND....had to move again...is working now (well sorts, math is wrong, DINT and INTs, I love newer PLC's)
Gambit Posted January 6, 2020 Report Posted January 6, 2020 3 minutes ago, wzrdstrm said: OK, memory checked as stated, thanks... So I moved everything only to realize they had a jump going to the FEND....had to move again...is working now (well sorts, math is wrong, DINT and INTs, I love newer PLC's) Excellent. Do you need any help with the math issue ?
