1 hour ago, tranthanhtung said:
Dear,
I'm trying read/write program from GT Designer to HMI (GT2708) via Ethernet.
However, I can't connect with HMI via Ethernet,
It popup messenge as attach file
Who have experience about this, pls share it for me
Thank you
ETHERNET.GTX
Hi,
  Is this is a New HMI or having program in it?
How you are connectiong to HMI is it Direct or Through Ethernet Switch?
Then the IP adress is probably different than then Default adress.
If there is a utility Switch than you can check what that IP adress is.
If not just read the program via USB first
both default/change IP address are same error
Hi,
  If you know ip address is it possible to ping with HMI?
 Check your laptop ip address also.
13 hours ago, krishna k said:
Hi,
Yep, I already ping --> it's ok.
But, can't connect from GT designer, it displayed as first post.
Hi,
       Then is the GOT is listdown in LIST screen that we can go through that List Button.
Or else contact me in my Whatsapp we can Discuss in Detail  +918610724575..
Maybe the port number was changed in the program. Also I would use a cross cable between the HMI and the PC or a separate switch to make sure there is not an duplicate IP-address
