Whenever I try to go to the communication setup on FT View studio I get the following alarm:
Unable to communicate with the FactoryTalk Linx server "localhost"
-Verify the server name is correct
-Verify the server's host computer is running
-Verify that the Ethernet cable is plugged in
I had been able to use FT View Studio before but it just started showing this message.
Does anyone have any ideas how to fix?
2 hours ago, mandrake8810 said:
Im having the same problem, did you fix it?
Yes. I will post 2 links that I found to fix it. The second link was the one that helped me. Basically my Display scale and layout for my PC (windows 10) was set to 150%. It needs to be 100%. If not it starts to flicker and give communication error. I do not know if this is your issue but look at the links below.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/33551
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/568264
