No, i think.
There is a workaround:
Define an array as VAR ==> CONST_LABEL1  (Uppercase indicates in programming a constant)
Define each constant as single entity at position 2,3,... in the dialog of your picture ==> CONST_LABEL_1, CONST_LABEL_2
At startup move these constants to the var.
Rule: Do never overwrite in your code anything which has all UPPERCASE.
If concern is that someone may inadvertently modify value, dont use array. Create function that has index as parameter and returns value. Index could be an onteger, enumeration, string or whatever you like.
