Hi all,
I have an FB (ST) which will calculate the UINT values that need to send to DA outputs. Currently i was requested to add a delay between the calculated output & DA units.
I am not sure how to do it? can I just use a TON? Any sample ST code?
How big a delay are you wanting to achieve?
You will need to push the current value onto a stack at a defined rate. Then move the last value of the stack to the output.
If you were to create a delay of 10 seconds updating every 100ms you would need 100 registers.
Try something like this. Time delay is adjustable from 0 - 10 Seconds
IF EN AND Run AND NOT Ring_Buffer_Initialize THEN
	Ring_Buffer_Write_Index:= 0;
	Ring_Buffer_Read_Index:= 0;
	Ring_Buffer_Size:= LIMIT(0,Time_Delay,10);
	Ring_Buffer_Size:= Ring_Buffer_Size*10;
	Ring_Buffer_Initialize:= TRUE;
END_IF;
IF NOT Run THEN
	Ring_Buffer_Initialize:= FALSE;
	RB_Loaded:= FALSE;
END_IF;
IF P_0_1s AND Run AND NOT ONS_Trig THEN
	Ring_Buffer[Ring_Buffer_Write_Index]:= Analogue_In;
	Ring_Buffer_Write_Index:= (Ring_Buffer_Write_Index+1)MOD Ring_Buffer_Size;
	IF Ring_Buffer_Write_Index = Ring_Buffer_Read_Index THEN
		RB_Loaded:= TRUE;
		Analogue_Out:=Ring_Buffer[Ring_Buffer_Read_Index];
		Ring_Buffer_Read_Index:= (Ring_Buffer_Read_Index+1)MOD Ring_Buffer_Size;
	ELSE
		RB_Loaded:= False;
	END_IF;
	ONS_Trig:= TRUE;
END_IF;
IF NOT P_0_1s THEN
	ONS_Trig:= FALSE;
END_IF;
thanks
It seems like a code for FB.
Could you please specify the input,output and internal variables and data type? I managed to identify some.
  • EN (bool) ------>INPUT
  • Run (Bool)------>INPUT
  • Ring_Buffer_Initialize (bool)
  • Ring_Buffer_Write_Index
  • Ring_Buffer_Read_Index
  • Ring_Buffer_Size
  • RB-Loaded (bool)------>OUTPUT
  • ONS_Trig (bool)------>OUTPUT
  • Ring_Buffer[ ] ------>INTERNAL
  • Analogue_In (UINT)------>INPUT
  • Analogue_Out(UINT) ------>OUTPUT
Appreciate all your help
Regards,
T J sharon
Edited by T J SHARON
Yes code for a FB
  • Ring_Buffer_Initialize (bool) internal
  • Ring_Buffer_Write_Index UINT internal
  • Ring_Buffer_Read_Index UINT internal
  • Ring_Buffer_Size UINT internal
  • ONS_Trig (bool)------>internal
  • Ring_Buffer[ ] UINT array [100] internal
  • Analogue_In------>INPUT
  • Analogue_Out ------>OUTPUT
  • Time_Delay  UINT INPUT
I put a bool output (RB-Loaded) that indicates the buffer is full and the time delay is active.
There is no value moved to the analogue output on start-up until the delay is reached.
Edited by chelton
missing variable
HI,
Its tested and working well.
I have 8 Analogue inputs and will be using 8FBs, which need 800 words for Buffer_Ring array.
But i don't have much free words in H-memory for Buffer_Ring array.
Is there any way that i can assign  Dmemory for the array? ( Assign "AT" in the Fb variable session not possible as this FB is using simultaneously for different Analogue inputs)
Can you increase the FB memory allocation area?
(PLC menu → Memory Allocation → Function Block/SFC Memory → Function Block/SFC Memory Allocation)
Another option would be to change the array variable from internal to an in/out variable the just pass a DM array in as a parameter on each instance
Hi ,
I already extended FB areas of H-memory. Is there any issue if I change my over all FB memory allocation to d10000 ?
Mean while I will try the feasibility of using IN-OUT  method.
I can not see any issue with changing the auto allocation memory area from H*** to D*** but I haven't had to do it on any projects.
You would just need to ensure the memory area will remain free.
D20000-D29599 and D30000-D31599 are for special I/O memory.
