xsienix Posted January 24, 2020 Report Posted January 24, 2020 Hello all, Recently i started to learn GX2Work2. I wonder what the program settings will do? I have some flavours to choose, like initial, scan etc. Is there a manual where i can find how this works, or is here someone who can help me. Many thanks,
AndreasW Posted January 24, 2020 Report Posted January 24, 2020 Hi xsienix, as far as i know the program settings will work like this: - Initial Programs will be executed once after startup - Scan Programs are the default and will be cyclic executed - Fixed Interval Programs are similar to Scan Programs, but use a fixed cycle time, that can be set in the Program Settings; Fixed Interval Program are only executed when Interrupts are enabled (with the 'EI' Instruction) from within another 'Scan' or 'Init' Program - No Execution Type won't be executed - Wait Programs: don't know, never needed these ones hope this helps
xsienix Posted January 24, 2020 Author Report Posted January 24, 2020 Hi Andrew, This is some great help. Thank you.
Gambit Posted January 29, 2020 Report Posted January 29, 2020 (edited) In the wait scan you van put sub programs or which can be called from other programs or interrupt programs. Als je meer wilt weten kun je hier een gratis trainingen volgen. https://www.mitsubishielectric.com/fa/assist/e-learning/index.html Edited January 29, 2020 by Gambit
xsienix Posted January 29, 2020 Author Report Posted January 29, 2020 Hi Gambit, I'am aware of the E-learning documents @ Mitshubishi. Unfortunaly, i can't find documents, with explaining the 'program settings' do. Perhaps i overlooked something? If you have information on that, please, be my guest.
Thiago Turcato Posted January 29, 2020 Report Posted January 29, 2020 (edited) Xsenix, I confess I don't use e-Manual much but PDF versions instead... In the link below, you will find the manual called "Fundamentals", in short. It contains explanations about the program types and how they work. Please take a look from page 54 of the PDF (2-13 of bottom corner page). https://drive.google.com/file/d/0ByjbLllAmf8CRl9PZGExT0taU2M/view?usp=drivesdk BR! Thiago Edited January 29, 2020 by Thiago Turcato
Gambit Posted January 30, 2020 Report Posted January 30, 2020 And here you can find all the latest manuals for the system Q series https://www.mitsubishielectric.com/app/fa/download/search.do?kisyu=/plcq&mode=manual
