Hi all,
I am trying to configure an Fx3ge-24M PLC using GX-works 2. I can successfully connect to the PLC using the USB cable, however i am having trouble getting a connection via ethernet. I have attached a photo that contains the only ethernet configuration that i can find, what am i missing here? I'm new to GX works & mitsubishi PLCs.
Try entering a subnet masking of 255.255.255.0 and default gateway of 0.0.0.0.  Then check that your PC is in the same subnet with a different IP address.
also make a melsoft connection in the open settings for ethernet
If you still cannot connect also post your transfer settings
Edited by Gambit
