noorloai Posted February 20, 2020 Report Posted February 20, 2020 Hi there, Recently we have a client who has code written in studio5000 using 1769-L30ER PLC. Most the codes written using AOI. Some of these AOI used to configure hardware of third party like reading/writing Beckhoff Ethernet IO Chassis. Client requires to move the AOI to Open Controller CPU 1515SP PC2 Using TIA PORTAL. My question, how can we establish communication between those controllers? How can data exchange between those controllers? By moving AOI to diffrent platform, how can studio5000 points to those AOI in TIA PORTAL? Is there any suggestion on how tags/ parameters transfer in this case? Is there anyone who have achieved something like this can help? Thanks, and appreciate your response in advance.
pcmccartney1 Posted February 20, 2020 Report Posted February 20, 2020 ProSoft makes and E/IP to Profinet Gateway. https://www.prosoft-technology.com/Products/Gateways/PLX8x/PLX82-EIP-PNC-EtherNet-IP-to-PROFINET-Controller-Gateway
noorloai Posted February 24, 2020 Author Report Posted February 24, 2020 Thanks pcmccartney1 for your response. My other question Can I Send /Receives UDT tags between those two controllers (Rockwell and Siemens) like Produce /Consumes tags between two Rockwell controllers? if so, how ? does this gateway enable my controllers to exchange UDT as well? Thanks,
pcmccartney1 Posted February 24, 2020 Report Posted February 24, 2020 I don't know, but I doubt it. You'll probably have to have tagging structures that are identical on both sides. Arrays of data types on both sides (udt and or FB/DB). Additional code on both sides to MUK/DEMUX the data. Prosoft has manuals and programming examples.
