Hi guys, my first try on Omron PLC and I’m having problem with the I/O.
I am able to trigger the inputs using 24Vdc but the corresponding outputs are not responding. I am using CP1E and my I/O address format is 0.00-0.11 and 100.00-100.07 respectively.
Can anyone tell me what could possibly go wrong? The power and run lights are on with nothing else lit. Thank you
I followed what I saw on a video guide and there wasn’t any error message. However, when I tried to force input using my PC, the PLC’s I/O does not respond. Tried when I set the operation mode in Monitor and Run and the result is the same
Go Online with the PLC.
Go to PLC pull down menu, then Transfer, then Compare with PLC.
They should match, if not, Transfer to PLC.
