hi dears
i have digital input and digital output modules (ID231 and OD232)
i want screw connector for them, whats is order for it?
i bought these module but in the pack there is not any connector for module. the connector must be ordered separately?
thanks
Those are 32 bit I/O modules.
There are no front screw connectors available.
You will need to use cables (XW2Z-xxxK) and screw terminal blocks (XW2B-40G5).   xxx in cable number = length in meters ie: 100 = 1 meter.
  • Like 1
thank you for your reply
that means that i must use screw terminal block and cable together?
i bought AD081 (analog input module) and it has front connector mounted on module.
i want to mount terminal block or front connector on Module, is there a solution for it?
Edited by cyrus
can i connect one side of flat cable to Digital Module and cut another side and connect wires of them to terminals?
flat cable has wire number?
my digital modules  (ID231 and OD232) is CS1D module (not CJ1)
ID231 in CS1D and (CJ1 or CJ2) wiring cable is similar?
can i use  XW2Z-xxxK  for CS1D-ID231 and CS1D-OD232?
Having trouble finding information on the CS1W-ID231 and CS1W-OD232.
I think these are Fujitsu style connectors, but not sure.
If you look at the front of the module, Are the top and bottom somewhat rounded, or are the straight?
