dear All,
I faced a problem that is password problem.I give a password on my fx5u Plc Couple of month ago.but I can't memorize this password.Have any Option Reset Data?i cant communication with plc.every time ask remote bpassword.Please Give the solution
You still have the program right.
Than you can clear the PLC via
Online - PLC Memory Operation - CLear PLC memory
After this the PLC is again in factory settings
i didn't connect with plc.need remote password.if i can communication successfully with PLC then i can reset the password as per your Suggestion .But I can't connect with plc.pls give me solution
It won't ask you for the password when you clear the PLC. If you don't have the original program on your PC than we cannot help you.
  • Like 1
I have FX5U and when I try to open CPU MEmory Information, it ask me for a password.
Is It another option to make factroy reset in this CPU.
I found a solution. You must stop the procedure halfway
  • Pun in SD card with new firware
  • Turn on PLC
  • Reset PLC
  • Wait until run and error stop blinking
  • Turn off PLC nad put out the SD Card
After that PLC uptade the firmware but don't dowland the BCK program from SD card.
Hii all,
If you have backup of the program, then you can follow the below steps to remove the password in Mitsubishi FX5U PLC
1. Open GX Works3
2. Change PLC to STOP mode
3. In the top navigation tabs, Click Online -> CPU Memory Operation...
4. Then CPU Memory Operation Pop up will open
5. There you can find Initialization(F) button below, Click that
6. Another Pop up will open, Click YES in that
7. Now RESET your PLC, and then keep in RUN mode after few seconds
Your FX5U PLC will be ready as brand new PLC without any password and program in it. After that you can download whatever program you want
NOTE: Try this only if you have the program backup file with you
Edited by Riswan Ahamed
