Hello,
How to use task control? I don’t know if it’s the right tool to solve my problem, so I’ll explain maybe there’s another tool,
I made an update to the program adding alarms to a program, using function blocks, after the download I realized that the machine was slow, I realized that the cycle time increased,
how to prioritize scan in my sections, and when possible check this alarm section?
Any suggestion?
PLC CP1L,
I appreciate the attention.
Lucas Abreu.
Set the Task Properties as a Cyclic task but with Operation start unchecked.
Then only call the task from your main program with a oneshot [rising edge bit] to trigger a TKON instruction.
At the very last rung of the called task place use LD CF113 [always on] followed by a TKOF.
Task will only run once when called from main program.
Picture shows Cyclic Task 01 with Operation Start unchecked.
