Hello , I dont have much experience in PLC coding but need to remove an old Fx1N with a QCPU . The program has several STL statements as State relays and dont know how to convert them for the new QCPU . I did export the old program as cvs and then imported it to a new project but I got many yellow code ( Errors  I assume ).  So far I managed to find the corresponding  Special registers needed M8002 to SM402 and for   [ ZRST M3 M200 ] used the [FMOV K0 K1M3 K200] but I am stuck at [ZRST S0 S100] asit gives me error plus it gives me yellow on each line there is a S device plus there are many STL that I dont know the equivalent of in QCPU .
Help and guidance is needed,
Thank you in advance
Arthur
PS. Please forgive me for my bad English as is not my first language .
Attached is the full program in GXWorks2 1.91V
me commente_greasepump_91_X15.gxw
You are not going to be able to convert the stl to a Q
Or in fact many instructions.
Stl in the fx is a set of conditional steps where only the active step is scanned.
You would be better with an fx3 or fx5....Or it's a rewrite.
  • Like 1
Thank you Ron
So how are "sets of conditional steps where only the active step is scanned"  expressed in Q ?
In short, they aren't.
The Q doesn't have that function.
In the fx, individual steps are defined by a line -----------------[ STL S20] etc
(program for s20 here)
STL S30 and so on
If stl s30 is active, none of the other steps are scanned
  • Like 1
So the only way is to rewrite it based on SFC , If I understand correctly . I find the manual for SFC programming https://dl.mitsubishielectric.com/dl/fa/document/manual/plc/sh080041/sh080041x.pdf very intimidating for a noob like myself .  Can someone help/guide me thru this process of converting the program to Q , and maybe some tutorials about mitsubishi SFC .
Thank you in advance,
Arthur
Just read your FX code and make write down the SFC chart on paper.
Than recreate it in SFC. For all the transitions use ----(TRAN) as an output.
  • Like 1
What should I use as input for the (TRAN)
the FX code is just some initial conditions and a section of manual use for the outputs then 5 STL statements and some Error routines on the end . for as I understand it .
Edited by arthurb4x
That would be the part in front it the ----[SET Sxxx]  in your FX code.
You can also recreate the STL yourself with SET RST instructions i suppose.
Edited by Gambit
  • Like 1
What should I do about the [ ZRST S0 S30 ] that cant be converted . It gives me error when I try ..( The Sxx are the STL statements ).I have already started the SFC prog
Is that a Reset of the whole SFC ?
If it programmed at the beginning you wouldn't need that. If it is part of the SFC than you can make a R block and use 999 to reset all SFC's
or just define the ones needed to be deactivated
  • Like 1
yes.
so M12 and X11 should be your condition before TRAN
You can find this example in the FX programming manual
Edited by Gambit
  • Like 1
You can remove the S4 as you are already in S4.
You are using the SFC so all the -[Set S...]-  and  -| |- S..  at the beginning are no longer needed.
  • Like 1
