Hi,
I'm looking for a way to change the button graphic (From "non-pressed button" to "pressed button" which is much lighter) via script.  The main problem is that, the button has to change it's graphic whenever i change a bit in my PLC program, more accurately, I press button in Factory IO, not in HMI, that thing I've already made, so I've set up my button "is pressed" graphic. I've got my tags prepared correctly, and I'm trying to reach the property of the button with this script:
Do
 If SmartTags("Variable_1") Is True Then
    HmiRuntime.Screens("Screen_1").ScreenItems("Template_Button_2")
 End If
Loop
Is it even proper way to do stuff like that? I THINK it'll work like, if Variable_1 (Bool %Q0.0 for e.g. in PLC program) is 1 Then ->  And when I'm at ScreenItems, i don't know which property should I choose next in order to change button graphic.
Hope you can help :)
