pszczepan Posted May 6, 2020 Report Posted May 6, 2020 Hi I noticed problem that I cannot use INI inside FB. It supposed to look like attachment. Whatever parameters I set CXP inidcate error
chelton Posted May 6, 2020 Report Posted May 6, 2020 (edited) You may have to assign the PV word to an address. Create an internal address on the function block and assign that to the PV. To expand on this, "0" is actually an address in a program it refers to CIO0. So although you are not using the PV on your configuration you will still need to assign it to a memory address. Edited May 6, 2020 by chelton
Michael Walsh Posted May 6, 2020 Report Posted May 6, 2020 24 minutes ago, chelton said: You may have to assign the PV word to an address. Create an internal address on the function block and assign that to the PV Yes, using real addresses inside a function block ruins its portability.
Sergei Troizky Posted May 7, 2020 Report Posted May 7, 2020 (edited) Edited May 7, 2020 by Sergei Troizky
