cyrus Posted May 22, 2020 Report Posted May 22, 2020 Hi dears, How can i see the cpu used memory in cx-programmar and actual cpu( for example 20%, 30% or etc) Best regards
Michael Walsh Posted May 22, 2020 Report Posted May 22, 2020 With respect to program capacity, View pulldown menu, then Memory View
cyrus Posted May 24, 2020 Author Report Posted May 24, 2020 On 5/22/2020 at 11:56 PM, banker said: Use the cross ref. in CX-programmer Banker thank you for your reply. i could not find it in cross ref., can you explain more?
cyrus Posted May 24, 2020 Author Report Posted May 24, 2020 On 5/22/2020 at 0:16 AM, Michael Walsh said: With respect to program capacity, View pulldown menu, then Memory View thank you for your reply, in siemens PLC we can see how much memory is used ( for example 50%). now in omron in memory view i can not find this item, can you explain more?
BITS N BYTES Posted May 24, 2020 Report Posted May 24, 2020 Select "View" and in pulldown "Memory_View". 1
Michael Walsh Posted May 26, 2020 Report Posted May 26, 2020 On 5/24/2020 at 2:38 AM, cyrus said: thank you for your reply, in siemens PLC we can see how much memory is used ( for example 50%). now in omron in memory view i can not find this item, can you explain more? What I told you shows used and available. If you need percentage, do the math. 1
