HMI.JR Posted June 15, 2020 Report Posted June 15, 2020 I have data logging set up in my GT27 and I can get it to save to the USB (as long as the USB in inserted obviously). I was wondering though if you can save all the log files to the USB by inserting a type of switch? I've been playing with it but been struggling. Any help would be appreciated. Thanks! Quote
Gambit Posted June 15, 2020 Report Posted June 15, 2020 You can save to a server or you can copy files to the USB after inserting it. Quote
HMI.JR Posted June 15, 2020 Author Report Posted June 15, 2020 I've looked through the offline menu but don't see where i can save the logging information to the USB. Is there not a way to use a word switch with an internal device to trigger the save to USB function? Quote
Gambit Posted June 16, 2020 Report Posted June 16, 2020 It's not mentioned as saving to USB bit to a drive. But never mind that what you want is to have a button on your screen which will copy the info to the USB drive. There is an example project for that. Script_File-Copy_V_Ver1_E.pdf Script_File-Copy_V_Ver1_E.GTX Quote
