ANTIA, Yakiseabasi Posted July 3, 2020 Report Posted July 3, 2020 (edited) Hello guys, i would appreciate your help ASAP. I have an Omron PLc CQM1H-CPU51 ON FATAL ERROR 0*00C0 (IO bus error). First, Im using this CPU51 to replace CQM1H-CPU 21 which is on I/O Unit over fatal error 0*00E1. I have changed the cpu type to 51 and transfered the program sucessfully with no errors, I have also transfered the memory area settings to CPU51. what other configuration settings do i need to do? I followed the instructions in the manual and: 1) io unit end cover is well connected, and even replaced with another, problem persists; 2) PLC has no inner boards; 3) No expansion block 4) Power supply is okay 5)I/O control unit or I/O interface unit not in use 6)Checking through the memory area, for AR 2400 to AR 2415 for the error code, the address here stops at AR 27. How can i view AR 2400 etc? Edited July 3, 2020 by ANTIA, Yakiseabasi
BobB Posted July 3, 2020 Report Posted July 3, 2020 It is dead! The bus has a problem. Replace it with a CJ2M. 1
ANTIA, Yakiseabasi Posted July 4, 2020 Author Report Posted July 4, 2020 8 hours ago, BobB said: It is dead! The bus has a problem. Replace it with a CJ2M. Thank you BobB.
