EL-HADIRI Posted July 7, 2020 Report Posted July 7, 2020 HELLO ! i'm beginner on omron and i would like get your help . i'm trying to establish a communication between an API CP1L-M40 and my computer using CP1W-CIF41. i have succeed this step, now i can upload/Download the program from and tp the PLC . my problem start when i try to use CX-DESIGNER and create a supervision , i can't link between the CX-DESIGNER and the PLC .
IO_Rack Posted July 7, 2020 Report Posted July 7, 2020 Do you have an NS touch screen or are you attempting to simulate in CX Designer? To simulate CX Designer with a real PLC: Create a PLC connection in CX Designer. PT > Communication settings... Serial PortA, Change Serial Port drop down to PLC. (Make appropriate settings) To simulate: Choose Tools > Test... Connect to PLC. Then choose the Host Name. By default, it will be SERIALA.
EL-HADIRI Posted July 8, 2020 Author Report Posted July 8, 2020 thank you for your reply . i don't have an NS touch screen , i work only with computer and i would like to do a supervision from my computer not in an NS touch screen . and i use the ETHERNET using CP1W-CIF41 . i don't know if there is a different between the cx-designer and cx-supervision . cause i don't have an NS touch screen and i work with cx-designer , should i use cx-supervision rather than cx-designer ?
IO_Rack Posted July 8, 2020 Report Posted July 8, 2020 I have not used CX Supervisor in a very long time. I see that it is still available. https://automation.omron.com/en/us/products/family/CX%20Supervisor I would think that it would be a viable option for your application but I would defer to other forum members here to confirm this. I would also check with your local Omron distributor. They may be able to supply you with a demo. I do know the CP1W-CIF41 supports Omron's FINS protocol. This is common with most of Omron's products.
Crossbow Posted July 10, 2020 Report Posted July 10, 2020 To create screens on a PC, you should be using a SCADA software, such as Indusoft. CX-Designer does offer a licensed mode for creating a CX-Designer project and running it on a PC, it's called NS-Runtime. But you need to buy a license. You can't just design something in CX-Designer and run it forever on the PC without a license.
IO_Rack Posted July 10, 2020 Report Posted July 10, 2020 Crossbow, He saying, "cx-supervision " but I took that to mean CX Supervisor (at least in my second post). Omron's SCADA package. I'm not well versed with it.
Crossbow Posted July 12, 2020 Report Posted July 12, 2020 On 7/10/2020 at 0:46 PM, IO_Rack said: Crossbow, He saying, "cx-supervision " but I took that to mean CX Supervisor (at least in my second post). Omron's SCADA package. I'm not well versed with it. No sir, he said using CX-Designer to create a supervision... I assume he means a display.
IO_Rack Posted July 13, 2020 Report Posted July 13, 2020 I misunderstood. If you are choosing a SCADA (PC application) then I would go with Crossbow's suggestion. Indusoft will give you more function, it supports Omron PLCs as well as many others.
EL-HADIRI Posted July 21, 2020 Author Report Posted July 21, 2020 hello yes Crossbow , i want to create a SCADA (PC application), i find that it's possible to work with CX-SUPERVISOR but i don't have a licence . my real probleme is in the hardware , exactly with the option bord CP1W-CIF41, i want know if it's possible to work with it to create a SCADA and communicate between th PC and API using this carte
IO_Rack Posted July 21, 2020 Report Posted July 21, 2020 3 hours ago, EL-HADIRI said: i find that it's possible to work with CX-SUPERVISOR but i don't have a licence . Yes, you are correct. Contact your local Omron distributor. They may be able to supply you with a demo. 3 hours ago, EL-HADIRI said: my real probleme is in the hardware , exactly with the option bord CP1W-CIF41, i want know if it's possible to work with it to create a SCADA and communicate between th PC and API using this carte Yes SCADA is possible with the CP1W-CIF41. If I'm not mistaken, all of Omron's Ethernet ports will communicate via FINS protocol. I know the CP1W-CIF41 will. https://www.myomron.com/index.php?action=kb&article=1212
Crossbow Posted July 21, 2020 Report Posted July 21, 2020 CX-Supervisor is just one of many SCADA software options. There are others that can also communicate with that CPU, such as Indusoft.
