Hello everyone, i have a question about a kind of output.
I have a PLC Compactlogix L23E QBFC1B and the last module the high speed counter has outputs
I want to use one of the outputs as a regular one
However, it shows me a lot of kind of outputs, which one should I use as a regular digital output?
The datasheet shows it has digital outputs
And the options the module gives me non of them are regular data.
Thank you
I think you should use the 1769-HSC reference and try to refer back to this module. Try to set it up on that module 1769-HSC and see how the tags changes then manually change the tags for this shoe box.
