denise01 Posted August 29, 2020 Report Posted August 29, 2020 Hello, I would like to receive data from our PM5100 Power Meter via Modbus using a Omron PLC. I am sure that it will use Modbus RTU as I have controlled Altivar Inverters using this system. Does anyone know where I can access the Modbus Registry for this Meter? I really want to log KWH usage. Regards Peter
cHud Posted August 31, 2020 Report Posted August 31, 2020 Hi Heres a link to the lists https://www.se.com/za/en/faqs/FA234017/
denise01 Posted September 1, 2020 Author Report Posted September 1, 2020 Many thanks cHud. Have you ever extracted value from the PM5100 before? I am sure I have to use Modbus RTU but maybe I will have to purchase a PM 5110? Regards
cHud Posted September 1, 2020 Report Posted September 1, 2020 Havent done it for a while. But we normally would use modbus tcp/ip to a gateway and the gateway would be modbus rtu to the different power meters.
denise01 Posted September 1, 2020 Author Report Posted September 1, 2020 How I did the Altivar Inverters was to use a Omron RS485 Communication Card to the Inverter. Download a Modbus RTU Protocol Macro to the card and then Read and Write values through ladder diagram programming using the registers. I know that we can buy Data Logging additions for the PM8000 but hopefully I will be able to retrieve data using my method. Regards
