FX3u can't connect to HMI Proface gp4301T throught FX3U 232 BD board
Hi everyone
  I have tried connect proface HMI model GP4301T(using com1) with FX3u throught FX3U 232 BD
I setting  and wiring cable as below ,please show me why I can't connect between them
Thanks for your support
Edited by ngocphonghd92
I've not used the latest software or HMI's, but with the GOT1000 & GOT2000 with RS232 you have to set enable the 5Volt power supply in the HMI utility setup for the comm port.
Steve
Sorry should have read the post carefully didn't see it was a proface.
On the same note - try selecting it to VCC, I think this is similar to the GOT's.
Edited by nehpets
Thank for your strong support
I did as both of you said
- Change protocol From non-protocol ---> Dedicated protocol
- Change in proface to VCC
, But It dosen't still work
What must I do .In control program I have wirte Mov k0 d8120 ---->> not effective
Hello Gambit
Please give me some recommend
 I'm going to share data between fx1N (FX1N485 BD Board ) and Q melsec ( module QJ71C24N )
about FX1N side, I'm going to wirte program by RS instruction to send and receive data
QJ71C24N side,I'm going to wirte program by IN.PUT and OUT.PUT instruction to send and receive
is that ok ?
And frame of RS instruction start by a character STX  and end of frame by a character ETX
Is that ok ?
I hope get some your recommend  as soon as possible
Thank you
On 8/31/2020 at 10:47 PM, ngocphonghd92 said:
Hello Gambit
I'm successful.Thank you for strong your  support
Hai Ngocphonghd92
I have same problem to, how to solved it
could you send tell me the procedure ?
BS
Widadi
