Shubham Thakur Posted September 1, 2020 Report Posted September 1, 2020 Hello, I have a project where i need to communicate Siemens S120 drive with Mitshubishi Qseries PLC over Profibus. So somebody can help me with the steps how could i communicate.Since i have a profibus card in mitshubishi Connected with PLC. Thanks and Regards Shubham Thakur
Gambit Posted September 1, 2020 Report Posted September 1, 2020 Have you got GX works 2 and GX configurator DP installed?
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 (edited) I have GX works2 also GX configarator DP. Edited September 1, 2020 by Shubham Thakur
Gambit Posted September 1, 2020 Report Posted September 1, 2020 You will also need to install GX config DP otherwise you cannot select the QJ71PB92V card.
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 (edited) I have already installed it and now actually i dont know what to do in the plc side also in the drive side of siemens Edited September 1, 2020 by Shubham Thakur
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 16 minutes ago, Gambit said: You will also need to install GX config DP otherwise you cannot select the QJ71PB92V card. I have installed it but dont know what to do know in mitshubishi PLC and in Siemens S120 so if you can help me with the step by step process with some document and backup
Gambit Posted September 1, 2020 Report Posted September 1, 2020 On the side of the siemens I cannot help you but for the Mitsubishi I can tell you the basics. Add the QJ71PB92V module to intelligent Function modules. Double Click on the parameter under the QJ71PB92V module. (profibus configurator should open) Add the GSD file for the Siemens S120 drive Drag and drop form the Drives folder under global database the Siemens S120 onto the profibus network. Give the slave a station nr (for the rest of the setup check the siemens documentation) double Click on the master module QJ71PB92V. Select the baudrate you need (at first it best to test on a slow baudrate). press next check Automatically generate code. press finish Now when you close the tab a library should be created and a program for starting profibus
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 Could you please help me with backup and some document where i can read it please its an request
Gambit Posted September 1, 2020 Report Posted September 1, 2020 https://www.mitsubishielectric.com/app/fa/download/search.do?kisyu=/plcq&mode=manual
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 In that link lots of manual are there which one i should follow
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 Thankyou Gambit for your help. And yeah could you please give me anybackup regarding this.
Gambit Posted September 1, 2020 Report Posted September 1, 2020 Sure if anything is not clear let me know
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 If you can provide me a backup its would be helpfull for me and where i will get gsd of s120 to add in mitshubishi
Gambit Posted September 1, 2020 Report Posted September 1, 2020 I do not have a backup as i have never used the Siemens S120. The GSD file should be provided by Siemens.
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 How would i install GSd file in Mitshubishi
Shubham Thakur Posted September 1, 2020 Author Report Posted September 1, 2020 Can you please provide me a link to download GX configurator DP. the one I have is not working. maybe it is corrupt.
waynes Posted September 1, 2020 Report Posted September 1, 2020 Shubham, You should download the manuals for the products you are using and read through it first to get an understanding of how it works. As for the software, I believe that it is bought software and that it cannot be simply provided. All information provided by Gambit thus far is correct.
