mr_electrician Posted September 22, 2020 Report Posted September 22, 2020 Hello group. I am having difficulties selecting a specific ARRAY position that comes from a CJ PLC into SYSMAC for NA5 HMI's I have created a Symbol called Bump_Lift_Offset as a DWORD and an array size of 5 resulting in DWORD[5] starting at D8740 I am trying to show on the HMI the value listed in each array address but the software keeps crashing when I type in for example Bump_Lift_Offset[1] which would be my second position in the array resulting in address D8742. I have tried various Data Types on the Sysmac side with no luck. I have attached a few images to provide a better explanation.
Michael Walsh Posted September 22, 2020 Report Posted September 22, 2020 Well, you are mixing up your data types 3 different ways here. The MOV instruction is a single word move instruction. The DWORD data type is a 2 word data type and LINT is a 4 word data type. i would suggest perhaps using DINT (in both CXP and Sysmac) and MOVL in CXP. If you are having trouble entering the TestArray[1] nomenclature (in my example), just type D2 (in my example) and it will put the proper array nomenclature in for you. CX-Programmer is letting me do this:
mr_electrician Posted October 28, 2020 Author Report Posted October 28, 2020 Ya I think I was having a bad day!!!! Thanks for the second set of eyes as this cleared stuff up!!
