DB backup in S7-300
Hi! I'm looking for the way to make backup for S7-300. I'm find that the structure of DB offline with symbols don't match DB online in PLC. If I simply copy all DB online to offline project i loose all symbols. How is possible to make backup for DB and do not loose symbols? Regards Ed
If the structure online differs from the structure offline, it won't be possible to upload a DB without loosing the symbolics. So before you make adjustments to a DB's structure, first upload the actual values, then make your adjustments, and download. However, it is still possible to monitor the actual values using a VAT table.
