So I am working on a project where I am using "XFER" command and I am trying to move some words from a place into location: global_variable_1[Variable2]."Struct_Name"[INT1].member1.
The problem is that whenever I try to make "INT1" into a tag variable with data type integer. It does not work. I think this is considered a 2D array? Is this even possible? Also I did see other posts that sounded similar, but I could not make a direct connection. I have some other PLC's in my facility that seem to be able to do this with Sysmac Studio, but not with CJ2M and cx-programmer.
Is this possible to do what I want and if not is there a work around?
That's not a 2D array, it's an array inside a structure.  But I am more familiar with Sysmac, not sure if CJ2M had this option or not.  Why is Struct_Name inside quotes?
