Wonderware and/or Nematron Demo
Guest prs1025
I need to be able to view the graphics only (no code needed) for PC based wonderware files (InTouch I believe) and Nematron (ViewBuilder) HMI's that link to PLC. Does anyone know of any tricks or shrotcuts to be able to do this?
I don't know about Nematron but as for Wonderware Intouch, best is to capture printscreens from where the application is running. If you can't do that and don't have an Intouch license, second way is to install the full Intouch app and run it in demo mode. You should then be able to import screens from your application for viewing. The tags and scripts for the screens will be indexed (disabled) so that they won't add up on the 32 max demo tags count. You should be able to get a copy of the Intouch for demo purposes from your distributor for free. I don't think there's any other programs that can view the screens.
