Good morning!
i am using  old PLC, SYSMAC C200HS , with CPU021. I am having the following problems: I load the program from the PC to the PLC and I can connect and see everything but the values in the memory are not restored such as position presets .. and comparison numbers...
There is a function to clean and be able to reload said values which appear to be present in the program on the PC but are not loaded into memory, or others tests that I can use to solve my problem?
Thank you
Bruno
Double click on Memory in the Project Workspace.  If some windows open up with the data in them, you can download the memory areas (usually DM area, perhaps HR area).  If no window with data opens up, you can click the open button and browse for a file that may be separate from your project.  If this file does not exist, then there is no way to get the data back in the PLC besides manual entry.  I would add some pictures, but something is wrong and is not allowing me to do so.
  • Like 1
