DJSauce Posted March 7, 2005 Report Posted March 7, 2005 Hey guys, I need to put a A1SJ71(U)C24-R2 card into an empty slot on my A2SH(S1). -Why do some models of this card have a "U" in them and some don't? -What are the steps I need to follow to place this card aget it going....I've heard I have to write some code to "initialize" the card. Id this true? -I am try to connect to a PC via the C24-R2 card - what kind of cable would I need. Any help is greatly appreciated....cheers! Quote
calvin Posted March 8, 2005 Report Posted March 8, 2005 Hi I use an A1SJ71(U)C24-R2 with a A1S CPU. I found this pinout in the manual (zip file), I not accurate if is the cable I use. Got work, you still need to make the sending and receiving code serial.zip Quote
calvin Posted March 8, 2005 Report Posted March 8, 2005 Hi again About the cable, I search in my docs and find the pinout for the cable I use, see attachment. This cable is for connecting the A1SJ71UC24-R2 to a PC, i use another for connecting two PLC's, basically is just making the same shuntings in both ends (4 to 6; 1 to 7 and 8). Quote
