Jhops123 Posted December 11, 2020 Report Posted December 11, 2020 Hi, I am completely new to mitsubishi PLCs, I have a beckhoff back ground. I have to familiarise myself with Gx works 2 for a project in the new year, I have some sample programs that I am trying to understand. The program I am looking at (I cant post NDA) has 5 tasks with a bunch of POUs in each task. When you hover over a task it pops up with attributes like always,event... Could anyone point me in the direction of some documentation that explains how tasks work and how to set theses attributes? I tried looking at some manual but cant find any description of this. Many thanks
AndreasW Posted December 12, 2020 Report Posted December 12, 2020 Hi Jhops123, have a look at Q-Series Basic & Advanced Course (for GXWorks2): https://eu3a.mitsubishielectric.com/fa/en/dl/12449/SH(NA)-081123ENG-A.pdf https://eu3a.mitsubishielectric.com/fa/en/dl/12448/SH(NA)-081124ENG-A.pdf the task settings are descibed in chapter "6.2 Program execution management" of the Advanced Course (second link) you should also have a look at GXWorks2 Operating manual https://eu3a.mitsubishielectric.com/fa/en/dl/9541/sh080779.pdf regarding your question about the tasks: - Initial Programs will be executed once after startup - Scan Programs are the default and will be cyclic executed - Fixed Interval Programs are similar to Scan Programs, but use a fixed cycle time, that can be set in the Program Settings; Fixed Interval Programs are only executed when Interrupts are enabled (with the 'EI' Instruction) from within another 'Scan' or 'Init' Program - No Execution Type programs won't be executed, usefull to temporary disable a program - Wait Programs: programs that are executed on request (e.g sub-routines, interrupts, events) hope this helps
Jhops123 Posted December 13, 2020 Author Report Posted December 13, 2020 Hi Andreas, thanks for the reply much appreciated! I will have a read of those manuals.
glavanov Posted December 13, 2020 Report Posted December 13, 2020 This link is your friend: https://www.mitsubishielectric.com/fa/assist/e-learning/eng.html
