Hello.
Im trying to make changes in one POU and when pressing the online change button it tells me to do a rebuild all, after doing that and pressing online change it tells me that I need to stop the cpu and do a download of the entire project, clear the memory and what not.
Im using Gx works 2 and it is a q02cpu.
I have only worked with Siemens before so I Dont have any experience with Mitsubishi plcs.
Thx for help.
Hi Thestaar,
have a look at chapter "15.9 online change" and chapter "12.2 option setting list"
in GXWorks2 Operating manual, https://eu3a.mitsubishielectric.com/fa/en/dl/9541/sh080779.pdf
check the "execute online change by compile" option in section 'onliine change', and the
"Turn PLC to STOP at time of PLC write after executing Rebuild All and do not execute remote RUN" option in the PLC Read/Write section
Hi Thestaar,
I think the message is clear, because after reassigning devices to the labels (what takes place after a rebuild all command is executed)
it can't do an online change. I think if you already did a rebuild all, you have to put the cpu to stop to write to plc, if its done
and both program & controller matches, you should be able to do a online change after a compile (not a rebuild all!)
if option "execute online change by compile" is selected and option "turn plc to stop at time of PLC write after executing rebuild all and do not execute remote run"
is cleared
Okey thx Andreas.
But even if I dont do a rebuild all it still gives me the same message. But okey I need to put the cpu in stop and dowload the program.
I did a verify and got some mismatches, I just wonder if I need to be concerned. What I can see is that some devices have different device ids.
Please se the screenshots below.
https://imgur.com/a/zYAY41g
https://imgur.com/a/P3Jbzh9
Hi Thestaar,
i think that your project isn't up to date (mismatch in program file) and that this is the cause, why you can't do an online change.
Maybe you should try to read the program from plc (be sure to first make a backup of your project file) and then re-verify the project.
(the deviation in the device data is usually not a problem, don't let it confuse you, the important thing is that the program file matches).
If the program file matches you should be able to do an online change
I'm experiencing the same issue. The rebuild to the labels causes the devices to be off by 1 and creates a mismatch after doing a read. Wanting to avoid a download. Any one have a solution?
