locleabc98 Posted December 25, 2020 Report Posted December 25, 2020 Hi every one, I want communication Inverter mitsubishi D700 with module CJ1W SCU31-V1, any one give me a correct solution and send any sample program. Thanks
Wasan Posted December 28, 2020 Report Posted December 28, 2020 @locleabc98 You should check OMRON Modbus Function Block at this link below. https://www.myomron.com/index.php?action=kb&article=1245 Then you should config D700 to use Modbus Communiaction at this link below at page 201. https://dl.mitsubishielectric.com/dl/fa/document/manual/inv/ib0600366eng/ib0600366engg.pdf
locleabc98 Posted January 3, 2021 Author Report Posted January 3, 2021 On 28/12/2020 at 09:02, Wasan said: @ locleabc98 Bạn nên kiểm tra Khối chức năng OMRON Modbus tại liên kết này bên dưới. https://www.myomron.com/index.php?action=kb&article=1245 Sau đó, bạn nên cấu hình D700 để sử dụng Modbus Communiaction tại liên kết này bên dưới tại trang 201. https://dl.mitsubishi Electrical.com/dl/fa/document/manual/inv/ib0600366eng/ib0600366engg.pdf I had a problem, I want to read holdding register 41005 but it not run https://drive.google.com/file/d/1MwQxXtHlqAgxkWdxNJj3lONsHrhR2bDK/view?usp=sharing can you have me? thanks. @Wasan
