Akhmad Zaki Posted January 11, 2021 Report Posted January 11, 2021 I have a Siemens HMI 6AV2 124-0MC01-0AX0 in my machine. I want to clone the display on the HMI to PC/Laptop. My question is: 1. What software that I need for this task? 2. What kind of interface that I need between the HMI and PC/Laptop (for example ethernet cable, etc)? 3. Do I need to communicate with PLC connected with HMI or can I just connect with the HMI? Thanks in advance for the answer. Quote
Moggie Posted January 11, 2021 Report Posted January 11, 2021 (edited) The TP is connected to the PLC via Profinet. (look at the back of your TP to see the connections) So you can connect the laptop to the PLC via Ethernet interface. You will require TIA Portal / WinCC runtime software and the TP Project. The laptop will need an IP address in the same range as the TP & PLC Edited January 11, 2021 by Moggie Quote
