smd.hannan Posted January 18, 2021 Report Posted January 18, 2021 MY OMRON CJ1M CPU12 SHOWS UNIT NUMBER DUPLICATE ERROR. ERROR CODE IS 0X80E9. THE CPU HAS TWO NUMBER OF HIGH SPEED COUNTER IN A RACK SOME AND I/O UNITS. PLEASE HELP HOW TO SET MACHINE NUMBER (ROTARY SWITCH) IN OMRON CJ1W-CT021 IF TWO UNIT CONNECTED IN ONE CPU. PLEASE SEE ATTACHED PICTURE. CJ1W-CT021.bmp
Michael Walsh Posted January 18, 2021 Report Posted January 18, 2021 The Special I/O Units (Blue letters on part number on front of the card).The memory areas for the modules cannot overlap. Typically each special I/O module takes the space of one unit number. However, the CT021 uses 4 slots. If you have a unit #0 CT021 module, it uses the space reserved for unit #0 - 3 and the next module should be at unit #4 and would then use the space reserved for units 4-7.
