sathu Posted February 12, 2021 Report Posted February 12, 2021 hey guys, im completely new to GX Works and for a school project i need to print the program i made into a pdf file but when im trying to print it it will ask for " Please create CSV file from the product Information List of System monitor. any help or advise?
Crossbow Posted February 12, 2021 Report Posted February 12, 2021 You should be able to select a printer and select Microsoft Print to PDF if you are on Windows 10. CSV files are for exporting data.
panic mode Posted February 13, 2021 Report Posted February 13, 2021 as mentioned newer Windows version come with PDF printer. IF for whatever reason it is missing, you can install your own. CutePDF or any of 200 or so others. this allows you to create PDF from any software, just choose to "print" to a PDF.
Local_PLC_Noob Posted July 1 Report Posted July 1 I had the same problem and the reason it asks for CSV is because you have "Product Information List" box checked. Uncheck that and now it no longer needs a CSV.
