tmu Posted March 10, 2005 Report Posted March 10, 2005 Hi, Bluetooth-Serial -converter http://www.bluetoothupgrade.de/promisdspecs.htm to PLC-programming cable or terminal port. Range max 100meters and no slots are needed, no parameter modifications. Just plug in and "play". No batteries to bluetooth, because RS-port normally have 5VDC output. Working?!? Give me reason to buy/reject... Thanks, Tmu Quote
waynes Posted March 15, 2005 Report Posted March 15, 2005 Hi tmu, How do you get hold of this? Sound quite cool! Quote
