 hi everyone i m traying to   write to plc  a program and getting this message then program is not downloading to plc   'there is a device in the program (main) that is outside of the range
check the program and currect the device that outside of the  range '
I m using mitsubishi fx3ga-60mt  plc.
please suggest me about it .
                             thank you
just jump to the error. There should be a device.which is out of the range.
For instance D10.000 is used but if yin the program but when you  check the PLC parameters Device tab the D range is only D0 - D9000.
  • Like 1
