raynvd Posted February 24, 2021 Report Posted February 24, 2021 Hello, does anyone know the best connection method between an S71500R/H profinet MRP ring (2 x S7 1500R controllers in redundant profinet ring) and an S7400 DP Master ?
jrw Posted February 24, 2021 Report Posted February 24, 2021 Have you read this? https://support.industry.siemens.com/cs/document/109771853/how-do-you-operate-dp-slaves-on-a-redundant-s7-1500r-h-controller-?dti=0&lc=en-US
raynvd Posted February 24, 2021 Author Report Posted February 24, 2021 1 hour ago, jrw said: Have you read this? https://support.industry.siemens.com/cs/document/109771853/how-do-you-operate-dp-slaves-on-a-redundant-s7-1500r-h-controller-?dti=0&lc=en-US 1 hour ago, jrw said: Have you read this? https://support.industry.siemens.com/cs/document/109771853/how-do-you-operate-dp-slaves-on-a-redundant-s7-1500r-h-controller-?dti=0&lc=en-US Hi. Yes i saw it. In my case i want to interface the S7 400 as DP Master instead of a DP Slave, so the S7 1200 shown on that example would be a DP slave, will it still work? Also is there another PB/ PN gateway I can use apart from the S7 1200 plc?
