thisiswerdz Posted February 25, 2021 Report Posted February 25, 2021 I have an NS5-SQ01-V2 that i pulled a program from. I am reloading the same program back onto the PT but i keep getting an error code that the "Program is V1, PT is V2. Continue Transfer?" I know this means that the versions obviously differ but this is the first time ive come across this. Will it do any harm to anything to continue with the transfer and see how the machine reacts? Quote
photovoltaic Posted February 25, 2021 Report Posted February 25, 2021 Should be fine, however if you want to do the proper conversion you can change the HMI type in CX-Designer before you download the program to the screen Quote
