ratcliffe_ic Posted February 26, 2021 Report Posted February 26, 2021 Hi, I have the following STL code in an old S5 processor, can someone tell me if I've transcribed it to ladder correctly please? :O F11.0 :O F11.1 :( I81.6 :AN F11.2 :AN F11.2 :O I81.6 :A Q64.3 :) :A I64.6 :A I64.0 :AN F3.6 := Q64.3 F11.0 I81.6 F11.2 F11.3 I64.6 I64.0 F3.6 Q64.3 [ ]---------[ ]-----[/]---------[/]--------[ ]--------[ ]-------[/]-------------------( ) | | | F11.1 | | I81.6 Q64.3 | [ ]------ ---[ ]------[ ]------- Thanks in advance
sigmadelta Posted March 9, 2021 Report Posted March 9, 2021 On the 3rd line, you're missing the instruction. If your original STL is like this: :O F11.0 :O F11.1:O( :A I81.6:AN F11.2 :AN F11.2 :O I81.6 :A Q64.3 :) :A I64.6 :A I64.0 :AN F3.6 := Q64.3 Then the logic would look like the attached picture. I tried it also with the third line as A(, but the logic doesn't make sense this way. Please check your STL code you posted, and make the necessary correction.
