Technicus Posted March 2, 2021 Report Posted March 2, 2021 Dear, I've just started using GX Works and I need to convert an old program made in GX Works2 to GX Works3. I've already solved most of the problems, but the a 'K0' command is not allowed in GX Works3. Current situation: The current step value is compared with ;'K0 ',' K1 'or' K2 ' My question: Is the 'K' value in not accepted GX Works3? Should I use a different value?
Gambit Posted March 2, 2021 Report Posted March 2, 2021 (edited) You can just delete the K. K meant decimal value. In GX works 3 it is a decimal value by default. of in andere woorden... Gewoon weg laten die K!!!! Was dat bij importeren niet automatisch verwijderd? Edited March 2, 2021 by Gambit
Technicus Posted March 3, 2021 Author Report Posted March 3, 2021 15 hours ago, Gambit said: You can just delete the K. K meant decimal value. In GX works 3 it is a decimal value by default. of in andere woorden... Gewoon weg laten die K!!!! Was dat bij importeren niet automatisch verwijderd? Gambit Duidelijk;) No, it didn't correct it automatically thanks for your reaction!
