AndrejP Posted March 5, 2021 Report Posted March 5, 2021 Hello. Is it possible to hard reset (power cycle) the CP1L-E cpu unit using software? I'm having difficulties, because when you configure IO MAD42 card via CIO registers, you have to power cycle the PLC. The problem is, that I remotely configure the PLC. If I put PLC to program then to run mode, the configuration fails to update. Is there some kind of BIT to do "virtual" power cycle? Thanks.
