On 3/15/2021 at 10:55 AM, Gambit said:
The settings are described in the connection manual. Check this first if you have any questions after you can post them
Hi gombit dear, I have another question, sorry if my English is poor ،how i can 2plc fx3u ethernet connection together with fx3u-enet-adp?
I was able to connect hmi ?
Thanks for your guide
Well this is not really possible.... They don't support fixed buffer/socket communication. you will need an FX3U-ENET module for that.
But if you need to share data between them and it doesn't require fast speeds than you can let the HMI do it.
Take a look at "Device Data Transfer" in GT Designer
Can you teach me?
How to configure the module FX3U-ENET with PLC FX3U?
And how to network 2 PLCs together and be able to control the inputs and outputs of each PLC?
thank you very much
On 3/30/2021 at 1:26 AM, Crossbow said:
The manual for the FX3U-ENET clearly indicates how to share data between PLCs.
Thankful....
I have a question?
What is the difference between a module FX3U-ENET-ADP and a module FX3U-ENET-L?
In fact, when the module FX3U-ENET-ADP and when the module FX3U-ENET-L is used?
Thank you so much
FX3U-ENET-ADP connects on the left side of the PLC, and is basically a serial to Ethernet adapter.  It's primary use is programming over Ethernet.
FX3U-ENET is used for controller networking and HMI connection.
FX3U-ENET-L is a lite version, it was not sold over here so can't tell you what the differences are.
but i connected 2hmi with fx3u-enet-adp
however i dont know how use the fx3u-enet-l and how configuration and how programing with module.of course i readed manuall fx3u-enet-l but i dont know >
thank you so match,dear  crossbow
I know Mitsubishi EU made some FB for the ENET module to connect to ENET ADP via MC protocol.
But you'll need to make an account to download them
Edited by Gambit
this is to hard,dear mr gambit
this is to hard,i never know it.please help me:-(
