stevencgj96 Posted March 26, 2021 Report Posted March 26, 2021 Hi all, Recently I am having a project using the QJ71C24N-R2 serial communication module to communicate with another machine using RS-232. In this project, I will need to send command to the machine and receive data from the machine. I had come across the predefined protocol support function in GX-Works2. Just want to know if I had configure the protocol inside the predefined protocol support function, does this means that the module will keep send the command that I had configured without the need of writing ladder program?
Gambit Posted March 26, 2021 Report Posted March 26, 2021 You still need a program but only a few lines for executing the protocol and opening a connection.
stevencgj96 Posted March 26, 2021 Author Report Posted March 26, 2021 Do you have any example or reference I can have a look?
Gambit Posted March 26, 2021 Report Posted March 26, 2021 should be in the e-manual viewer or pdf. just serach for pre-defined protocol. it should have an example.
stevencgj96 Posted April 7, 2021 Author Report Posted April 7, 2021 Do you know what is the difference between non-procedural protocol and pre-defined protocol?
Gambit Posted April 7, 2021 Report Posted April 7, 2021 non procedure is where you basically write the protocol handeling in your program When you are using pre-defined protocol you use use the pre defined protocol support function in your software, where you can create sets of Requests and replies, In your sequence program you will only need to activate them.
