Andrea Ascani Posted April 21, 2021 Report Posted April 21, 2021 Good morning guys, in your experience what is the best way to syncrhonize a motor controlled in speed with an inverter and a motor controlled in position with a servo drive? Let me explaine better what is my situation: I have a belt running normally at a certain constant speed. in some moments, I would like to syncrhonize the speed according to an axis controlled from a servo. the command of a servo specific position target and of course speed and acceleration e deceleration rate. I would like to adjust the belt speed in way to follow as accurately as possible the servo movement. Thanks a lot Andrea
Crossbow Posted April 21, 2021 Report Posted April 21, 2021 Best bet is an encoder on the belt, and then you can use gearing or camming to sync the two. 2
