Hello,
   i have one questions. Is possible upload program from  SIEMENS LOGO MEMORY BATTERY CARD ? If is possible ... how?
   Thank you for your help.
    Regards Beny
Hello Beny,
I am a bit confused by your question:
You want to retrieve program from a battery cartridge?
Or from a memory cartridge?
My English is poor,  but I have some experience with LOGO and I intend to help you.
Hello,
   thank you for your replly.
   I want to read program from " memmory battery card ". It is memory modul inserted into LOGO.
   The modul is inserted on the programming position .... when I remove the modul ... PLC clear the program from PLC memmory. I need to modify Logo SW, but i can not download the program.
   Regards Beny
Hi,
I guess that the LOGO hardware that you have is an old version, lower than LOGO 7.
I know that the same connector is used for programming and also to insert memory cartridge or battery cartridge.
Edited by dekor
try to add details
What I understood is that you did not copy the program from memory cartridge into LOGO BM (base module).
1. You need to copy program into BM
2. Connect your laptop and upload the program from BM into your laptop.Save-it into you laptop.
3. Modify the program as you need and download-it int o BM.
Attacheed you will find instructions about working with memory cartridge.
Send me feedback about your progress.LOGO 6 working with memory card.pdf
It looks like I cannot attach the file. Please check next document from original link
You will find necessary info on pages 203-215.
https://cache.industry.siemens.com/dl/files/461/16527461/att_82564/v1/Logo_e.pdf
Edited by dekor
Impossible to attach pdf file.
Hello,
   thank you for your reply.
   I copyied program from Memory Card to the Logo BM. When I removed Memory Card from BM... program in BM was erased.
   What can I do about it?
   Regards Beny
Hi,
did you switch off and try to start BM without memory cartridge ?
Then was no program in BM?
Try to copy and remove memory without power off.
Was a password request when you copied the program?
Hello,
   when I start BM without memory cartridge ... there is no program.
   When I copy program to BM and remove the memory cartridge ... the BM clearing the progam.
  I discused this situation with siemens company and they told me information, that not possible download program from my BM model with this card :(  That is Know-How protection method.
   Regards Beny
Perhaps the program in the memory module is password protected.  I haven't seen this, and haven't touched a Logo in a decade. But I did use the gen4 Logos a lot back in the early 2000s.
If the program is protected and cannot be downloaded to the unit, then the module must remain plugged in to run that program.
