Paolo_911 Posted May 10, 2021 Report Posted May 10, 2021 I need help reading values from a scale using a QJ71C24N-R2 module with a Q03UDECPU. I am using the FROM instruction - FROM H6 K10 D0 K5. The H6 I believe is correct since the QJ71C24N-R2 module is in the 3rd slot with starting address 060. I have no idea what to set as the buffer memory start address (K10?) and then I want the scale value to be in D0, reading K5 words (?). The QJ71C24N-R2 module RD light continuously blinks which might indicate it is communicating correctly (?) since I set the scale to continuously print / outputs its value. There are no faults on the C24N module. I had faults before I correctly set the number of data bits, parity and stop bits to match the scale settings. I used the scale manual for wiring and would attach pictures but the attachment link for this forum still isn't working. Any help would be appreciated, thanks! Quote
Crossbow Posted May 10, 2021 Report Posted May 10, 2021 Did you look at the manual for the C24 card to see where the received data is stored? That's the start address you need. And it will come in as a text string. You will need to convert it if you are looking for a number. Quote
Paolo_911 Posted May 10, 2021 Author Report Posted May 10, 2021 Solid advice. However, I flipped through the manual and it says the "Receive data" is stored in buffer memory address 1537 to 2047 (601H to 7FFH) so I changed the FROM instruction as follows: FROM H6 K601 D0 K1 and FROM H6 K601 D0 K50 and even monitored the buffer memory and did not see any values in that area. Should I look elsewhere or would that suggest I'm not communicating with the scale properly? I have weight on the scale so it should be sending a value. Quote
panic mode Posted May 11, 2021 Report Posted May 11, 2021 prefix K indicates that decimal literal (integer) follows. prefix H indicates that hexadecimal literal (integer) follows. so K601 is 601 but H601 is 1537 Quote
Paolo_911 Posted May 11, 2021 Author Report Posted May 11, 2021 Sorry that was a typo - I actually used K1537. I even went into the Online > Monitor > Buffer Memory Batch monitoring and scrolled through a ton of memory addresses and couldn't find any changing values based on a changing scale weight. Quote
Paolo_911 Posted May 11, 2021 Author Report Posted May 11, 2021 I am out of options and settings to change that I can think of at the moment. Please send help! :) Quote
panic mode Posted May 11, 2021 Report Posted May 11, 2021 well it looks like you are on a right track.... lets see.. make sure it it correct type of RS232 (some equipment uses TTL levels) make sure wiring is correct (uses handshaking lines and Tx/Rx are not reversed etc.) make sure to connect using correct settings. (baud rate, handshaking, etc.) do trial from different system using different software to send/receive messages. it needed use try other tools to verify that things are the same (could be adapter with LEDs to monitor state of each line, or datalogger or scope). compare messages. if the wiring is correct, ports settings are correct, message matches, it WILL work... Quote
Paolo_911 Posted May 11, 2021 Author Report Posted May 11, 2021 I am using bidirectional protocol. The scale manual shows wiring on PLC side to jumper pins 1,7,8 together (DCD,RTS,CTS) and then jumper pins 6,4 together (DSR,DTR). It then says to connect/wire pin 3 (TXD) on PLC to pin 2 (RXD) on the scale & pin 2 (RXD) on PLC to pin 3 (TXD) on scale & then pin 5 to 5 (GND). All the other wires coming from the scale (pins 1,7,8,6,4 are disconnected and just floating since they are jumped together on the PLC side. There is a tab when writing to the PLC called Intelligent Module Function where there is a checkbox "Valid" that I checked which apparently writes the settings/parameters to Flash ROM. This was recommended in the Mitsubishi training course on RS232 communication. I'm not sure exactly what this does or if it is necessary, but I did it anyways. I'm not sure how to make sure it is the correct type of RS232. The scale is a Vibra HJ-K. Quote
Nightfly Posted May 11, 2021 Report Posted May 11, 2021 Regardless of the serial device (RS232/422/485) I always feed it into a PC first to see what’s happening. I wouldn’t bother with all the jumpers, just wire 3-2, 2-3 and ground and monitor with your favourite Serial port Monitoring tool (there are a few free ones about). It takes out a lot of the guesswork as you will be able to confirm that the Scales are actually streaming the data, as well as the format it is in (but you will need a serial to usb adapter). Quote
Paolo_911 Posted May 12, 2021 Author Report Posted May 12, 2021 After doing exactly as you said, I was able to connect it to a PC and read the continuous output results from the scale. This now tells me there is a problem with how the PLC interprets the data. I have the same settings in the PLC side with baud rate, stop bits etc. I have attached photos of my setup. https://drive.google.com/file/d/1jS5XVtUIK9K5xUDsd0if1HQGXlC1mrDZ/view?usp=sharing https://drive.google.com/file/d/15APTcGdKzeal1nTav3mwUqN6BlcsN9U2/view?usp=sharing https://drive.google.com/file/d/16Zz-D3wSZcpesRqph1UZD41LFERXgW9W/view?usp=sharing https://drive.google.com/file/d/1WDF3yRkqhN3uNj7Cs1o-wgQL1GV1jrna/view?usp=sharing I'm still not confident that I am looking in the right buffer memory address area so if someone would confirm that is K1537 (H601) onwards that would be helpful too, unless my QJ71C24N-R2 settings are incorrect using Channel 1. That brings up another question I just thought of - how do you specify in the FROM instruction which channel you are using? Or rather does the buffer memory separate channel 1 and channel 2 areas of storage? I'm currently hooked up to CH1. Quote
Nightfly Posted May 12, 2021 Report Posted May 12, 2021 If it streamed data to the PLC continuously then I would query the use of the Bidirectional Protocol. Did you read that this was required somewhere? I would assume Bidirectional may want handshaking other than the software XON/XOFF that your 3 wire connection can give (and if it was streaming continuously to the PLC without software handshaking then the Scales are not using it). If so this could be why you are not receiving data. For streaming data perhaps the Non Procedure Protocol is the way to go. However, you will probably have to format the data yourself and often even have to find it in within the data array received. Quote
Paolo_911 Posted May 13, 2021 Author Report Posted May 13, 2021 I was able to successfully read scale values using nonprocedural protocol with the G.INPUT instruction. Thank you all for your assistance! Quote
