reejef Posted May 24, 2021 Report Posted May 24, 2021 Hi Guys I'm using the Control_ATV block to control all the Altivar drives, but now I have a Powerflex 525 installed into the system (M241 PLC). Who has successfully controlled a Powerflex over Ethernet/IP from Somachine, or CoDeSys? I have installed the EDS file for the drive, but I'm confused on where to next regarding either a control block, or another wat to control direction/speed etc. Thanks in advance
Mtr_T Posted May 14 Report Posted May 14 Hi reejef, I have run into the same problem. I'm attempting to control a Powerflex 525 using CoDeSys. I'm curious if you were able to get it to work, and if so, how? Thanks!
