I am trying to check LM9030 program logic online for some issues we have but I realize I don't have any copy of the program on the laptop am using. How do I proceed to download the running program directly from PLC onto my laptop?
Thank you,
In Logicmaster, the name of the project file you select in the computer running LM90 needs to match the name of the program in the PLC in order to be able to make a connection. The exception to that rule is when the project file is named "Temp". So, if you don't already have a project file with that name, create one. If one already exists, select it, then you will be able to pull the program from the PLC to the "Temp" project file(upload). You can then save it as the correct name. The variable names and rung comments are not saved in the 90-30 PLC's memory so when you upload all you will be able to see are addresses.
  • Like 1
Thank you so much Steve Bailey. Will do this now and should get out of my issues here.
Appreciate your help.
